knocking
210 dsm
268
24
Dec 6, 2007
san antonio, Texas
can anybody relate to a knocking oil pump?
has anybody ever had this happen to them. i have the stub shaft installed on the gear, and when this first started happening i pin-pointed the knock (using a silicon hose) coming from the oil pump sprocket on the timing belt side. what do you think happened?.
and by the way i was overboosting it when this happened, like a heroin junkie that dosent know when to put the needle down.ROFL.(but seriously) im just trying to fing out if its a main , rod , or what thats knocking. if it helps ill go record a video of me turning it on so you can see for yourself.
