turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Just wondering if anyone has ordered a Bosch 2 wire knock sensor to use in place of the OEM one? From talking with John at J&S it seems that the signal would be of the correct type and since it uses a bolt to pinch it down to the block, the possibilities for "dampening" the sensor would be about endless and only limited to how long the bolt is and how far away from the firewall the motor is. I was thinking some Nylon washers between the block and sensor and maybe using an aluminum bolt that wouldn't transfer near as much of the noise, especially lower frequency noises.. I am thinking that it is something that would be so tunable that it may actually benefit our community.
Let me know what you've tried besides stock
