Knock Sensor Problem
VZRacing
Mar 2, 2009
Danbury, Connecticut
We are getting a “knock sensor circuit malfunction” DTC.
We have tested the knock sensor wiring on the harness side- it tested fine. We have replaced the knock sensor itself with a new one (twice). We have tried grounding the knock sensor in many different ways.
Dsmlink v3 shows that with any significant throttle input (2% and over), the ecu pulls 3 degrees of timing. It always pulls 3 degrees and never pulls more than 3.
I’m guessing this is a safety measure given the knock sensor malfunction. We even ran a wire directly from the knock sensor to ECU pin 9 (detonation sensor) with still no results.
Does anyone have any suggestions on how to fix this knock sensor problem?
With link hooked up, can you create a knock and have it register on the screen?
I have tired simulating a knock as described in the Haynes manual by "tapping/hitting" the block with a hammer to see if the sensor picks anything up; DSMLink did not register anything. I also took the sesnor out, grounded it, and then hit it against the strut housing, with the same result.... nothing
faulty cable? Can you do you knock or see an error without dsmlink hooked up?
When DSMLink isn't hooked up the check engine light stays on. I don't think the cable on the sensor is bad since I have gone through 2. The wiring harness may be bad but I don't see how. One terminal read 8v exactly (Haynes manual says it should be between 8 and 11v), and the other terminal should go to pin 9 on the ecu. I ran a new wire directly from the knock sensor to ecu pin 9 and it's still throwing a code.
Another interesting thing.... the car throws the CEL when the engine isn't running; as in the car turned to the "ON" position.
As it turns out the problem was not our car! Apparently there was a problem with all ECU's the guys over at DSMLink sold this year for the 1990's. There is a resistor that needed to be installed to "pull-up" the knock sensor pin. After that was soldered in place everything started working properly!
They just put up a post today about the issue, if you are having a problem and bought an ECU for a 1990 from them recently you might want to drop them an email.
Their post:
If you ordered a 1990 EPROM ECU from us since December 2008 or you sent us a 1990 non-EPROM ECU for the EPROM conversion, please be aware that we have identified a compatibility issue in these ECUs related to the knock sensor circuitry. If you have one of these ECUs and are currently getting a knock sensor error, please contact us offline to arrange for a free fix.
twdorris at ecmtuning.com
I've already sent out e-mail to everyone I could find in our order database. But just in case I missed some, I wanted to post it here too.
Thanks and sorry for the inconvenience,
Thomas Dorris
Thanks to everyone who tried the help.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
