Knock sensor gone?
andytalon
277
7
Mar 27, 2005
Boston, Massachusetts
So I took my logger today and I had it idle. I was just fooling around with the logger and I noticed that I have 0 knock all the time (not tuned), but my O2-r is .11 and my O2-f is a constant 3.49. Anyone know why, do I need a new knock sensor???:confused:
If you are running super rich, then you will not monitor knock as it is not seeing any.
Check the condition of your current sensor, remove it, and look at the back, if the goo has run out and it gone then it needs replacing.
its in the back of the motor under the intake manifold gasket between the a/c compressor and starter motor. its got a wire going from it to the wiring harness.
