Kinetik Valve Spring Compressor
Looks like it would work. Don't expect the compressor to hold the valves shut though, didn't for me. Couldn't get the rope trick to work either.
Well i want to change the valve stem seals without pulling the head off. To tkelly, how much psi were you shooting in the cylinders? I don't mind use the rope in the cylinders to hold the valves, but it just seem like it would be a whole lot quicker to pressurize the cylinder,change the seals then slide it over to the next one.
