Valve spring compressor
904g63tlaser
Sep 25, 2009
Elyria, Ohio
IM in need of one does anyone in ohio perferably close to elyria have one 1 i can use ill even throw cash with it.... Im not tryin to go out and buy one cause i ###### wont need it after this and it expensive.... FROM ONE DSMER TO ANOTHER
I seem to remember a trick a certain someone I know did to bypass the need for one.
You'll Need:
A long socket...I think a 14-16mm will do the trick
A hammer
A steady hand
And basically all you do is position the socket on top of the spring and give it a good, solid smack. Keepers tend to fly around so keep your eye out for them.
:idontknow:
If you can't find a compressor then you could give it a shot.
Works great for disassembly.
For assembling, you need a compressor of some type. I slot-cut a cheap deep well socket (around 17-19mm) and compress the spring using a large C-clamp. The slot in the socket allows you to slide the keepers in with ease.
It's been a year or so since I've had to assemble a head, but I did three heads within three months and that C-clamp compressor worked super-slick when I was in rhythm.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
