2G Kelford 272/272 or gsc stage 2 274/274 cams
bmw335ikt
228
16
Sep 23, 2015
Crown Point, Indiana
Hello, new to this and want to buy cams will have built block and head will have ferrea dual spring kit and valves. I will be running the fp 68hta
Thanks
You don't really need that much valve spring, or cam with that turbo.
A set of upgraded single springs, and a real 272 cam around 212* of duration at .050" would work great. Either of those sets of cams are going to sacrifice some torque in the prime output range of that turbo, for torque in an rpm range not suited for that turbo.
Those cams are more suited to a 35r sized turbo.
Personally I would run some hks272's, or comp101200's/fp2's.
Good to know Donnie I just picked up some evo 8 springs and some hks 272 and fidanza gears been looking at running that turbo too.
Thanks I got the ferrea for dual springs for a deal. Would they be fine. Also where can you get the hks 272?
Thanks
