Just installed big 16g, now a few problems
97gsx_zeclipse
220
May 4, 2007
San Diego, California
I just installed a big 16g into my 97 gsx. I want to run off the wastegate psi, I don't have upgraded fuel pump or injectors, I want to run 12 psi or less. The guy I bought it from says when he had it installed on his car it was opening beween 8-12 psi but no higher than 12. So I'll be fine with that untill I get supporting upgrades. Well anyway I was going to run the vacuum lines just how I had the stock t25 lines. Turbo to wastegate, teed off to the boost solinoid, but my big 16g doesn't have a vacuum source. How would I go about setting up the vacuum lines with no turbo vacuum?
Are you using a stock 1G j pipe there is a nipple on that you use. If not and you have an aftermarket j-pipe you will need to drill and tap a hole and put a small fitting there to tap into.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
