Just bought a 99 GSX, some problems
ryanx99GS
247
Sep 26, 2005
St Louis, Missouri
Okay well I just picked up a 99 GSX with 69,000 miles. 1 owner. Has been sitting since it was last serviced at 60,000 miles (timing belt, etc). When I bought it I noticed it was only getting 15-16 MPG, quickly to notice the CEL came on and I needed a new MAF. Replaced that today as well as changing the oil to Mobil 1 Synthetic, putting brand new Denso Platinum plugs in (old plugs pulled had no sign of coolant being mixed in) and checking all the hoses, bolts etc. All 4 cylinders read 150 for the compression test. Quicky noticed that my gas mileage is back to normal, but the smoking while stopped at a stop light/sign etc is still there. Turbo has no shaft play what so ever. Is this due to a failing/leaking head gasket? Thanks
the NGK BPR6ES plugs are the best for every situation. i was using them even at 21 lbs of boost and they were holding up great!!! if you get those i wouldnt even worry about changing them colder unless its about time for new plugs
The compression in a2g engine should be around 170-190.
Yea, your right... if the engine is brand new. But with 70k on it is going to have lower compression.
As long as they are within 10% of each other and are all above 135 (I believe) your fine.
What color is the smoke? Also remember its winter time, so the cold will cause a lot more condensation to appear as smoke. This is perfectly normal. Does the "smoke" go away or become less apparent after more than a half hour of driving?
As far as the plugs go... NGK or denso will work. Obviously ngk is preferred, but I’ve never had a problem with denso!
Good luck! Sounds like you got a nice car.
MEH I had a 95 fwd until last march with 131 on orignal motor 2nd owner and had 173,180,180,170. then again it wasn't driven the way it was supposed to.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
