just bought a 2G Talon TSi
shogun7g
30
Dec 15, 2004
St. Charles, Missouri
what should I do? what are things you would do when you first buy a car that is on GREAT condition, motor, tranny, and body? i did the cone air filter and a the DIY mod taking out the wastegate solonoid restricion thing. but it runs great. i did the above and also plugs/wires. what else can i do to make it close to perfect?
5sp.<--shifts fine grinds every-once in a while into reverse
143k miles
many replaced parts
turbo spools nice and smooth
thanks
Steve
just basic maintenance is a good start :
oil/filter change, change the tranny/transfer case/rear diff. fluids, flush the cooling system, new thermostat, timing belt (if it hasn't been done yet), new brake pads, bleed the clutch and put in new fluid.
thats all i can think of right now...
