fifthgearvtec
- 84
- 0
- Aug 14, 2005
Greenville,
South Carolina
Ok I got a 1992 awd talon No Heat for one just cold air ! Tach Seems To Be Slow Reacting ! Who can Help Me ! And I have an Oil Leak From The Bolt On Top Of Turbo!
fifthgearvtec said:Ok I got a 1992 awd talon No Heat for one just cold air ! Tach Seems To Be Slow Reacting ! Who can Help Me ! And I have an Oil Leak From The Bolt On Top Of Turbo!![]()
well found out today radiator is leaking so im just gunna replace the radiator and hoses and thermostate while im doing this i should check the heater core u say ?femmeDSM said:Not going to recommend new spark plugs this time, Damien??
j/k. He's right -- drain and refill the radiator/hc. The heater core can get clogged keeping the warm air out of the cabin. I hadn't thought of that
fifthgearvtec said:well found out today radiator is leaking so im just gunna replace the radiator and hoses and thermostate while im doing this i should check the heater core u say ?
!fifthgearvtec said:the good old haynes manual!
fifthgearvtec said:Hey what can be the problem for my temp gauge not working to well ?
