A Few Unknown Problems, Help
EVIL EAGLE RT
78
Nov 7, 2007
ST. LOUIS, Missouri
ya so, i got my gauge one and running and settled in at 10psi. promblems though: 1) takes for ever to start wont fire upon cranking2) when running right now i have a vacuum leak my boost reads at idle -3 to -7 and rpms rise but evrything vacuum wire is plugged up, 3) check engine light came on. 4) small oil drops in area of oil filter bracket and everyhting is sealed i just replace everything there. 5) last but not least i pulled it up the driveway and the is nothing there i pull away in 1st and it barely goes anywhere and the gas is down like 25-50%. this car is pissing me off its one thing after another. any help would be greatly appreciated before water patrol is pulling it out of the mississippi
Fix the leaks is where i would start. and pull the codes. and tell us what you get.
P.S. dont let the car get to you had mine for 2 days motor went got it back transfercase locked. It just takes time to get these touchie cars just the way you want them. So be patient
