- Thread starter
- #51
Kyle_T
- 795
- 14
- Oct 19, 2008
Muskego,
Wisconsin
I think Ive narrowed it down to HKS 264/264, HKS 264/272 or GSC S1. Whichever ones I can find a better deal on.
You understand were I'm coming from with the real duration vs the advertised numbers. That's why im interested in the dsport cam test. 18 cams all tested that show the advertised numbers and the real numbers.FWIW we had comp 101200 in Tylers 16g car. It was running solid 10.7s at the track on the stock bottom end and our ZFG head combo. We knew the cam was holding us back so we decided to go after the crane 264/258 which is a huge cam in comparison to a comp 101200(FP2s). The car ended up running 10.4s with just the cam change. We did not have the dyno then but honestly that is a pretty big indication as to what can be gained when the right cam is picked. Don't be scared of a aggressive cam on a small turbo setup.
I will also add with some technical data to clear up all this "272"
The advertised duration("272, 264, 274, ect") is measured at .001 of lift or 1mm(.004). That number should only be used to get an idea of how aggressive the ramp is. The amount of airflow at that low of lift is damn near completely pointless to even choose a camshaft based solely off that number
Lets look at some things
Comp101200s-
Advertised @ .004- 259/258
@ .050 numbers - 212/212
Lift-.411/.398
HKS272s- Baby 272s. Thats why no one has issues with stock springs.
advertised "272s"
@ .050 numbers-195 / 195
lift-.399"/.379"
Crane 264s- You can see how aggressive these cams are. Nice split between the intake and exhaust. Small advertised for a clean idle with a serious @ .050 number and lift.
advertised- 264/258
@ .050 numbers-224/216
lift-.443/.424
Kelford 272s- larger advertise, slightly rougher idle, still a decent @ .050 number, modern camshaft profile.
Advertised- 272/272
@ .050 numers(actually at .040 numbers)-226/226(est @ .050 is 220/220)
Lift-.443/.443
!! And its needed because none of the cam companies us the same standards and the numbers may be off by different ratios. No guessing. Just unbiased numbers across the board. So I would recommend waiting to see the results to get the accurate info. If you can wait.Just read the d sport review on cams good stuff there too.
Not sure how much they cost for DSM but AWD Motorsport has them for Evo $459. Kind of messed up the generational gap there is on performance parts. I recall on one of the earlier post a guy never even heard of Jun. The Tomei cams for DSM's have the same specs as the Evo cams. And just because it made the most peak WHP doesn't necessarily make it the winner.For the evo guys the Tomei was the winner. Ive never even heard of the brand smh, Shows how much i know. These are for MIVECs right? I suppose the info would still be valuable to us though, either way.
Found Tomei 270,280, or 290 cams for ~$470 shipped. Could this be right?
I wish crowers were in the review...
those seem like a good match. the next cam after that is BC 272 and then the next cam after BC272 is HKS 280/DKS 3. Both are between comp 264 and comp 272.Been considering fp2/comp 101200 for my setup
here go some FP2 16g dyno's.Yea I haven't been able to find a whole lot of info with fp2's and 16g's but it seems like they idle close to stock and retain most low end but open up the top end a good amount. Would like to see some torque curves with these cams
Looking at it now I'm throw in Comp 101100 with HKS 272 and BC 272. They would give you almost No low end power loss. If you feel you can sacrifice a very very small amount of lowend with more push up top then look at Comp 101200, HKS 280 etc. As for the JUN 264's. Although they are a nice ass cam and you found a set for a good ass price. The fact is they just may be a little to big for your goals.Yea I haven't been able to find a whole lot of info with fp2's and 16g's but it seems like they idle close to stock and retain most low end but open up the top end a good amount. Would like to see some torque curves with these cams
