jumping out of gear
bud09
44
May 8, 2012
selinsgrove, Pennsylvania
It just started yesterday after driving for about 150 miles.I was going through a town in 4th and it jumped out into neutral, and it has happened now more often. It does out when I shift normal, just easy in not a lot of force, but that's when I jumps out. When I use more force it does pop out. I haven't been able to check to see if it's the linkage come loose, but I hope it's only minor. Thanks.
do you feel it in your clutch or in your shifter? mine does that about every day, but i feel it coming on in the clutch. The slave is going bad and you can feel it coming on. anyway, i just give the clutch a quick bleed and carry on my business.
Do you hear any noise in the tranny while cruising in like 5th? Mine starting doing that about a week before it blew up =0
2literking-no noise from clutch
4g63t- I actually thought a came may gabber cone loose
Beckholt99GSX-note no noise from tranny
Crazytsiawd-that's what my friends said, I don't want to believe our. He made it sounds expensive to fix. is it and estimated price?
