JMF or Punishment Racing Divided T3 Manifold and 2g Upper Radiator Hose
Strm Trpr
1,979
100
Jan 20, 2004
Lodi, California
Anyone have any insight on either of these two manifolds?
I'm looking ahead for any clearance issues on a 2g with a Fluidyne?
JMF's description on Extreme PSI's site says that a 2g needs
to have the upper radiator hose moved off center like a 1g.
What's the fix?
Any pics would be most excellent!
Will a 1g radiator simply drop into a 2g?
I'd rather not rework the 2g radiator.
I'll have a 2g Fluidyne that may be up for sale if so.
You may be able to have the upper hose location moved towards the passenger side if you have an aluminum radiator. Take it to a good welding shop and see what they can do.
And, yes the 1g radiator does fit in a 2g. I just think the mounting points are a little different.
Here a pic from another thread of a 1g in 2g radiator.
2g Radiator setup
1g radiator setup
I just used reflective heat tape and wrapped it on the upper radiator hose that's right next to the manifold. Hasn't failed so far... can't say that it's ideal though.
You can either go with a 1G radiator and move the lower mounting tabs or go ahead and use the 2G radiator and just do a metal upper hose that angles itself out of the way of the manifold runner.
I know I have seen some pictures on here somewhere, let me go grab some.
*Something like this that Flash has:
I've seen ^^^ before and thought that might work too.
I have a spare 2g upper rad hose that I might trim about 1-1/2" off of the portion that attaches to the radiator in an attempt to shorten that section and start the turn left (when looking down) sooner and not got towards the engine so much before turning.
Thanks for the help guys... JMF it is!
That wont work with the JMF manifold because it pushes the turbo out from the block and one of the runners hits the outlet on the radiator so he would have to do the 1G or something like I posted.
Pics requested by Strm Trpr of the JMF manifold and the radiator setup.
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
