Punishment racing o2 housing with koyo radiator?
That o2 housing is designed for any 38mm two bolt flange wastegate. TiAL, Turbosmart, PTE they would all fit.
I would not worry if it will kit the radiator, all radiator should be around the same size and provide ample space for the o2 housing. Its the fans I would worry about. What type of fans are you running? Slim fans are a must, you might even need to run one on the passenger side to make sure it fits.
Take a look at this:
http://www.dsmtuners.com/forums/turbo-system-tech/400945-punishment-racing-vs-map-o2-housing.html
If fitment is a huge concern I would go with a MAPerformance o2 housing. They are just like punishment with slight difference. Overall they have better fitment.
http://www.dsmtuners.com/forums/tur...-55-mvs-o2-housing-fitment.html#post152796225
