JDM valve cover
foxracing4500
336
9
Jan 21, 2012
Europe
I went to the junkyard today and I pulled a JDM valve cover, just curious if I was to post this in the classifieds how much could I expect or should I just put it on my car?
EDIT: changed link to picture. also JDM valve covers are the only ones with "Mitsubishi" on top right?
Ehhhh... it's just a valve cover. What it's worth depends on how badly the person you're selling it to needs one. :)
My guess would be $35 to $50, if it's in good shape and there are no cracks and it's not warped.
Personally, I would hang on to it so you have a spare, or one you can modify with better fittings if you decide to in the future.
Holding to it l. Not worth selling I think. Nice find though.
Also the jdm ones not modded..The vac line coming out of the left side there..That line should be l shaped and pointing torwards the tb..
Correct
Couldnt find a old picture of my valve cover.
:edit: found one, also a good shot of a evo III intake:thumb:
99% sure that is a Galant VR4 valve cover. My buddy bought one new back in 99 for his 92 4/6 Talon.
Only to brag..But I have an extra one of these.Still red fom factory with a non modded vac line.
I only offered it to one person, So no offers please.Unless you happen to be that person.
looks like my 7 bolt came with the 16 valve one, and my 6 bolt came with the mitsubishi one. i also have both, gonna powdercoat the mitsubishi one. and also plan on keeping both, since my 16 valve cover has some stripped and cracked bolt holes.
there is a difference i noticed on the 6 bolt and 7 bolt valve covers and that is that the 6 bolt VC comes with a 90* angle breather port as the 2g 7 bolt comes with a straight out breather port.
GoldÐiamond;153043264 said:
Wait, that car was in the junkyard!?
hell no LOL, I was using it for an example, I found a 2g eclipse with a im guessing a galant motor swap with that same valve cover on it.
EDIT: infact I reused the gasket and havent had one leak unlike my old one, also turned out nice with a quick sand and spray job.
This is mine,
Yeah, that looks really good.
Quick sidequestion on VC's: Are the PCV valve THREADS only good for one time use?
It seems like you cannot replace a PCV valve without stripping.:confused:
Don't mean to hijack.
they arent one time use, the valve cover is just soft material, if your wanting to delete the PCV you can always tap a 1/8 npt through hole into a catch can, if you intend on keeping the PCV you willneed to find a 1/8BSP tap to chase the threads.
