JB weld & Trust
non-turbotalon
May 15, 2004
laurel, Maryland
ok I need someones opinion on this. I broke my water outlet housing by tightening the bolts to tight. The dealership cant get one till tuesday. Well it cracked on the left side around the hole for the bolt about a 1/4 inch in. Im sopposed to go to the beach for the weekend and cant wait till tuesday will jb weld hold up till then its about 2.5 hour drive.
Yeah it should hold for you just make sure you let it cure for about 24hrs and use large amounts on it to make sure it doesn't leak and take a jug of water just in case. Later, Keith
Im gonna do it, I never could of imagined how strong this stuff really is. I did two thick coats, but I used the 4min jb weld. Then I took it outside and through it at the side walk as hard as I could. I figuard if it held up to that it should work. :p
I would still let it cure or sit for 24hrs before putting it on your car, and for exhaust leaks I wouldn't use it, for some reason it doesn't like hot exhaust very well, at least not on anything I have ever done.
