Jb Weld on cracked Valve Cover?
Outdorsman
338
Oct 17, 2012
Las Vegas, Nevada
Okay so I found out my valve cover was cracked AFTER I put in the new gaskets, stupid of me I know. I heard Jb Weld is good to seal it up but I was wondering, do you apply the epoxy on the outside or inside or both? Better to ask than have to buy a new cover haha if I do mess it up.
around my area a valve cover is only like $30.if your short on cash and want to use jb weld, im sure you can get away with putting it on the inside aslong as u clean the cover so there is no oil or any other impurities that might make it not set properley, hope that helps.
Ima go to the junkyard right now actually to see if I can pick up one haha. I can reuse the old gaskets I put on right? Well I wouldn't call them old since I got them yesterday and have only turned the car on once.
Yeah that should be fine. If you're talking a dozen on-offs, then I would replace it.
170km on mine, but about 6-7 on/offs, two dozen heat cycles and it leaks now
Alright so I went to the junkyard and found none, jb weld it is for now I guess. Jb weld in my motor? I plan on letting it set over night LOL.
I went to two different big junkyards. Not one single valve cover, checked hyundais out as well and none. I just jb welded it until I orderone online. The crack is pretty significant. It caused oil to leak ontop
Well sometimes CL can help.
you are in Sin City, Right?
Not to promote this guy but looks like he can have one or two valve covers laying around.
1G 2G DSM Eclipse GSX GST Talon TSi 4G63 Evo 3000GT
If that doesn't work keep looking there and the JunkYards., I bought one here at the classifieds section for about 40 bucks. :) In the meanwhile JB weld should work for some time.
Be sure you have the JB Weld cure with the valve cover torqued down. This means if you use 5 min JB Weld you will have to apply it with the valve cover on the car.
I would also suggest sanding across the area of the crack with 80grit while you have the cover off of the car. Be sure you make deep scratches for good mechanical grip. You can even use the corner edge of a file to make deeper gouges across the crack as well. Spray the area liberally with brake cleaner and you should be good.
I've seen these repairs last for a very long time and I've seen some fail right away so once it's on the car just keep an eye on it for leaks; maybe you'll get lucky. Then just replace whenever you come across a good deal on one.
So I put it on and immediately put the valve cover after applying the jb weld? I thought I was supposed to let it set outside of the car as per instruction on box.
The instructions don't take into account that the piece your fixing will flex a good amount. You can do it off the car if you are using regular jb weld but make sure it cures with the valve cover torqued down so it cures with the cover already flexed. If you only have 5 min jb weld you will have to put it on with the cover already torqued in place because you'll make yourself crazy trying to get it all together in time. Also, don't even start the car for about 20hrs or oil could contaminate the bond.
You should be fine installing another valve cover on a nearly fresh gasket. I'd advise against trying to repair a broken valve cover. There are a huge amount of valve covers in the marketplace section everyday (seems like 1 out of 10 ads has a valve cover, many are even powdercoated/painted really nice).
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
