j pipe?
ceth17
87
Feb 23, 2010
lubbock, Texas
will a stock 1g jpipe work on a 20g turbo
If you are using the SMIC then you would use the stock style passenger facing pipe. If you are using a FMIC then you need one that bends towards the drivers side.
I hope that you just don't have a fully filled out profile as you need fuel mods before you go and install that and run it.
yeah well im putting my talon back together and still buying parts. im using the SMIC as well
Yes, a 1g j-pipe can work with front mount or side mount. Just depends on what kind of frount mount you have and how it is set up. We have a spearco front mount kit with j-pipe. Being that it twisted in a different angle we used some of the leftover rubber piping and have a good clean seal.
