j-pipe
1. use real hose clamps (t-bolt type)
2. ends of the pipe needs to be beaded (use jb weld or have it welded or take it to a muffler shop and get then to flare the ends)
3. sand the pipe, so the silicone coupler has something to grip on to
4. use correct length pipes (if too short then maybe there is too much tension pulling it apart easily)
try those!
The couplers look to be your average rubber couplers, not the red or blue silicone. I'm already using T bolt clamps. Ill try beading the end as well as cleaning it with some brake cleaner first thing tomorrow. Would I be able to find the stronger silicone couplers locally? Like at an auto store or would cheapbay be my best bet?
