poteau
- 45
- 0
- Feb 21, 2013
Ottawa,
ON, Canada
I purchased my profecB (original one) from someone online as a used part. Since installing it, it has never worked right, but I have had so many issues with my car, I never bothered to troubleshoot it throughly, and figured it was just something wrong with my set-up. After installing a new tial bov, I figured it was time to get down to finding out what was wrong with it.
Regardless of the positions of any dials I am unable to get it to control boost, it just goes to the minimum setting (8 psi).
I have checked the continuity of the cables to the solenoid, and it's working.
I have tested the solenoid by using a vacuum pump on the 'in' port and the solenoid will build vacuum. If I connect a 12v battery to the two connectors on the solenoid, the solenoid does open and the vacuum disappears.
Other than this.. I have no idea what is wrong with it. I have opened the cover on the controller and there are a lot of adjustment potentiometers to play around with. I haven't touched anything yet.
The unit powers up, all the lights come on. You can switch between 'hi' and 'low' boost and hear a relay click.
After troubleshooting, I installed a brand new factory solenoid and the car boosts to 16psi (stock).
Ideas?
Ideas?
