is this Turbo oil feed tap correct?
javi-tsi
38
Nov 20, 2005
kaiserslautern, germany, Europe
is this Turbo oil feed tap in the correct place?
acbigshow said:
the stock oil feed is on the left side of the head if thats for an oil presure guage it should beok
SI I can't pull from there at all for the turbo oil feed? Which of those plugs should I use as an alternative to the head plug?
the oil feed off of the top of the head is unfiltered oil...that is why many people who run expensive aftermarket turbos run it off the oil filter housing because it is filtered oil and it wont run dirty, unfiltered oil through the turbo. if you do this route, you might have to restrict the oil pressure going into the turbo because you could actually overpressure the cartridge with oil and it will start to leak and burn in the exhaust or go into the compressor housing and make a huge mess....believe me been there done that on a homemade dune buggy.
:thumb: Thanks all! Great answers! I will leave it there and hope it turns out well. :talon:
