Is this still ok
GsX2Nv
Jun 7, 2004
Wichita, Kansas
With these upgrades will my 1 g maf be ok? Mods apexi n1 3" downpipe and turbo back, ported 2g manifold, Precision Turbo Engineering 57 trim turbo, greddy type s blow off valve, Jonny racecraft 25/8/2.75 fmic with custom 3" to 2.5 in intercooling pipes, fuel injection clinic 550 injectors, walbro 255 fuel pump, joe p man. boost controler, k&n air filter, evo o2 housing, 8.5 magnecore wires, boost gauge , safc 2, uego gauge type controller wide band, exh gas temp gauge. also what do u think would be safe to run boost with this set up. thanks in advance anyone with this same set up on a 92 gsx i did these over the summer planning on running it in may or jun to see what my impove time was from 15.2 thanks for all advice also we did a compression test it was about 150 is that good for a motor with 145k miles on it. or do u think it was rebuilt?
It sounds like your rings are still good, but I'm not sure how long your rods and or your rod bearings will hold up to 400 hp + of punishment. 145k is alot of miles, but who knows. If you tune it correctly and don't knock too much it MIGHT be reliable, but you should seriously consider building up a stronger block in the meantime, because that 145k stocker isn't going to last forever with that type of power going through it. I'd say start at 10psi and then work your way up (see what type of knock you get). You also need to UPGRADE your injectors, unless you plan on not running past 10 psi with that 57 trim (you can max out 550s on an EVO16G) or maybe upgrade your fuel pressure regulator to an adjustable one.
ok so the 550 was a bad idea so what should i have for a 57 trim also will a afpr work to get me the right amount of fuel?
i guess that would help so what do u think i can do if i max out the 550 injectors boost wise
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
