Is this engine a 6 or 7 bolt?
slowmoawd
Aug 14, 2011
grand island, Nebraska
I am looking at a 1992 laser with 4g63t in it at a salvage yard it say its from 7/1991. Would that be a six or seven bolt enigne??? thanks for the help
to be sure that its not a swapped 7 bolt, the easiest way is to check the exhaust manifold studs. the 7bolts got one lager bolt at each side. (left and right lower bolt)
Right, because no one has ever put a 7-bolt (either 1G or 2G) head on a 6-bolt block before. :rolleyes:
You want to be sure, check the block itself. But as JayB12 stated, if it is the original engine, it will be a 6-bolt.
