ECMlink Is this bad?
n0de
938
7
Sep 22, 2012
Bolingbrook, Illinois
Like the title says, except please give me an idea as to why this would happen at 9-15% throttle.
Also I have fixed the issue with my LC-1 wideband, the logged a/f is wayyyy off but has been fixed and will appear correct in any subsequent log that I post. DSMTuner forms was down ALL DAY LONG, I was waiting since 10am for it to come back up so i could research ECMlink v3 a little bit before I started logging/tuning but when the site wasn't up by 7pm my time, I decided to try and figure it out on my own, please take it easy on me.
Car - 1g DSM
Mods,
550cc injectors, EVO-3 16G Turbo, 2g MAF (Not Hacked).
Basically my settings are:
Narrowband simulation (the linked log is not using NB Sim)
-18.4 Global Fuel adj w 180 deadtime
MAF: send 2g maf
(yes i air calibrated the Sensor before screwing it into the exhaust)
I saved my settings, and well there you go.
Well apparently I am unable to post attachments :/
Want to post what the issue was and how you fixed it?
Sorry, you're right.
Basically the first issue I had was my wideband gauge and wideband logged in ECMLink being completely different. This issue turned out to be cause by using the wrong settings in the LC-1 software itself. The LC-1 has two axillary settings that can be configured which sends either narrowband or wideband ranges to the aux wire (which is what goes into the ecu), I set both aux settings to display wideband ranges. This fixed that issue.
The second issue I had was running extremely lean after 4100rpm. This turned out to be because my 16g was boost creeping/spiking past 20psi(maxed the gauge). I didn't fix this issue, i determined the body and condition of the dsm I had was not suitable for modding (Rust, bushings, springs, shocks, more rust) so I bought another dsm and am still working on building it at the moment.
