IS THIS A clutch PROBLEM OR A transmission problem?
jibberishballr
475
3
Aug 23, 2005
Chico, California
my car wont go into any gears without griinding....so basically i havent driven it for a week...i ordered a clutch kit..(since its got 85k miles and is still using the stock clutch) .but is that goin to fix the problem?
Try adjusting your clutch pedal, bleeding your clutch line, see if you have fluid left in the reservoir. This just happened to my car, turns out my friction disc exploded....
Transmission Diagnostics.
Gear Clash (Grinding noise when shifting):
a) Worn blocker rings (This is part of the synchronizer assembly).
b) Clutch not disengaging properly
Clicking Noise (Heard in one single gear with the vehicle in motion).
a) Broken or chipped part of gear tooth (It can be on the main gear, on the countershaft(clutch shaft) or output shaft (main shaft).
Generally Noisy (In all forward speeds)
a) Low lubricant or incorrect lubricant
b) Transmission not securely mounted
Growling Noise (With clutch engaged and transmission in neutral -- will also be heard on acceleration as a steadily increasing whirring).
a) Worn or faulty input shaft(Clutch shaft, main drive gear) bearing
Growling Noise (With the vehicle moving in all gears).
a) Worn or defective countershaft or bearings
Growling Noise (Heard in all gear ranges except 4-5.
a) Roller bearings that supports the main shaft at the front that is in the rear of the input shaft. These are either damaged or were missing (If you overhauled your transmission and forgot to put these back in).
Violent Banging/shudder (Heard and felt in the vehicle just starts to move--- this is caused by abuse).
a) Broken main drive gear teeth.
b) Broken main clutch gear teeth.
Slips or jumps out of gear (Visually occures on acceleration and deceleration.
a) Loose synchro hub on the main shaft splines.
b) Worn synchro insert grooves on the synchronizer sleeve.
c) Bearing at the front of the main shaft disintegrated causing the shaft to wobble.
d) Worn detent mechanism
e) Worn thrust washers/helical gear axial movement.
Anyway, those are the basics. So if you are having any of these issues, consider this write up.
Jesse
i would deffinetly replace the clutch disk, pressure plate, and flywheel, i had a similar problem with my car, but in some cases it might be the tranny......good luck
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
