Is there any way to fit evo 8 parts on 2g
no you need a custom built manifold
down pipe and you have to relocate the mas o build a custom intake solution...
for what? the same general power as an evo 3 with a DP and SMIM?
I've seen it done on a 1G, Im sure you could do it on yours, all you have to do is: remove PS, relocate the alt. which means you must remove a/c and since there is no room for a maf you have to get a MAFT and run blow-through. then get the evo 8 manifold/turbo/o2/ downpipe and your set. its a good amount of work, most likly a days work and a decent amount of pocket change to did it all but all the parts would be for the better(performance or weight reduction), help you run some good 1/4 miles.
OR keep everything on your car and get an evo3 16g and call it a day
I don't know, I think it would be easier to just buy a turbo upgrade, but if you want to be different, And have a 16g off an evo on your car.. I guess that's up to you.
On another note, If you post something out of the ordinary on this site, I found that you will get flamed and told it's impossible and all.. Some dumb asses tried telling me i coulden't put the 7cm 16g turbine housing on my 14b.. :notgood: :rolleyes:
