evo 8 brake master cylinder fit on 2g?
It won't fit straight on, some good fabrication will need to be done. Why don't you just use your oem 2g brake master cylinder like the guys who have done their evo brembo conversions ?
You won't gain any extra stopping power from the swap.
I would think with the bigger calipers all around would need more brake fluid, therfor the 2g oem master wont give them what they needto work at ther optimum performance? The 2g calipers are smaller then the brembos and their master cylinder is designed for just that? Im doing the swap at the moment and since im going brembo I would like for them baby's to work just like they do on the evo??
Ive got a 2g rx7 with a lt1 and t56 6spd trans in it and the oem clutch master would not displace enough fluid to disengage the clutch all the way. So I had to get a adapter plate from grannyspeedshop to fit my willwood master in my car for it to work properly?
I just want to know if anyone has came across anything like this??
