Is the Greddy Emanage right for me?
Brian O Conner
333
35
May 8, 2011
Sheridan, Indiana
Hello guys I have been doing some research on the right management system for my setup. I have been asking the past few days and searching the forums. Thank you for my struggle on finding the right device for me. I have been wondering if anybody knows if the Greddy Emanage will work with my setup. I haveT3/T4 turbo, 720cc injectors, Msd coil pack, msd wires, NGK spark plugs and a Walbro 255 phl fuel pump and wanting to run 20 pounds of boost. My questions is this will the Emanage work with this setup? Also is the Emanage easier to install than the Megasquirt system(what I mean by this is buying wiring harnesses, saudering wires, stripping wires, twisting wires and buying fuses to put in certain spots)? Also I realise this device is harder to use but is its fuel to air ratio wider than adding 50% like the SAFC2(meaning can I add and subtract more air and fuel than the SAFC2)? Will this device work with my Setup at 20 psi? Guys I really appreciate the help on this struggle. Also if this device does work what else will I need besides a wideband? Will I need to buy a wiring harness?
Anything that works off our MAP sensors work like hell. You can jimmy rigg it but it still really sucks.
PMed with better explanation.
Also
http://www.dsmtuners.com/forums/420a-engine-management/306413-safc-2-boosted-420a.html
I tried the safc 2 and emanage blue - Both sucked horribly.
Go with MS2 or MS3 if you have the cash.
Also, checkout 2GNT.com. All NT wonderfulness.
...Thats my best friend on the main page too!
No, it's painted black now. It's two toned now.
