This is right...right?
LD25Delta9
694
16
Feb 12, 2008
Ft. Wayne, Indiana
Most of the other diagrams I have found seem exactly like this one, but then again, all had reference only to stock setups. I hope that this is correct, as I am using all aftermarket -6an lines, Rail, Filter, and AFPR. If it's wrong please correct me.The exact position of where the Send and Return lines are may be off but I know the difference between the two.
Will do, will do. I knew I should have said something about the vacuum line too....ROFL Thanks for the quick responses.
Locke, if you want, mark this post as helpful if you think it might help out. I know there are a couple of diagrams on here that are real similar and I wouldn't want to so schmuckin anything up....but if there's a specific space, you should exploit my superior MS Paint Skillz:cool:ROFL
