zheter
- 0
- Jan 22, 2025
Spring,
Texas
I have a 1998 Eclipse GSX. Today I resealed the oil pan using Permatex Right Stuff RTV and did an oil change at the same time (Mobil 1 10W-30). Everything went back together fine, and there are no major oil leaks. The oil level is also right at the full mark.
My concern is the oil pressure. Once the engine is fully warmed up, the factory gauge drops to almost the bottom line at idle. While driving around town it comes up to about 1/4 of the gauge, and on the freeway it climbs to nearly halfway.
Is it normal for these cars to show such low oil pressure at warm idle, or should I be worried?
From what I've found while searching, a faulty oil pressure sending unit is a possibility, but I'd like to hear from anyone who's experienced this before.
Should I verify the pressure with a mechanical gauge first, or are there other common causes I should check? I really don't want to risk damaging the engine.
