Is it necessary to use DSMlink or similar program
There are many alternatives to DSMlink, but is by far the easiest and most idiot proof. Depending on what size injectors you have, you could get away with a simple SAFC.
You should post up what setup you plan on going with. Then I can tell you if its absolutely necessary.
You need to fill out your cars information so we know what were dealing with. To answer your question, if you have larger injectors, then yes you need something to tune it with. You don't NEED dsm link, but its nice. Also, if you are using injectors larger than 650cc they can be a pain to tune with an afc. Otherwise the SAFC would be the easiest device to tune with. Depending on the size of your fuel pump (if its a walbro 255) your gonna need and AFPR so you dont over run the stop fpr.
Like they said, you don't need the link, but I would very much recommend it. You won't be sorry, it is just so easy to use, and that way if you do decide you need bigger injectors later down the road you won't have to upgrade again.
Since you have a 95 car, you may already have a EPROM ECU. It is easy to tune using a free program called tunerpro and burn your own chips with a burner such as the burn1 from moates.net. I think it's the easiest way to tune, and it's the cheapest considering the burner is only $85! This way gives you full control over the timing and fuel maps; dsmlink does not.
