is it necessary to remove the cam sprockets...
Kiiii
37
Sep 9, 2009
OXNARD, California
while changing a head gasket? i looked up the service manual and it talks about removing the camshafts, so im just curious. this is on a 420A eclipse btw.
hm some people told me it wasnt necessary to remove the camshafts when doing a head gasket. perhaps that only applies to turbo models?
The cam shafts will need to come out, just take the time to organize all of the cam caps in order as they come off.
4g63 models is different the head can be removed without taking off the cams.
420a is different some bolt are just under the cam shafts .
And while you are it check the flatness of your head and the deck of your block.
