balancing a crank.... is it necessary
99eclipse420
250
Jul 7, 2011
irmo, South Carolina
hey guys, im getting my enternals and gaskets tomorrow and so I can finally go to the machnine shop and get the motor bored, but is it necessary to balance the crank I blew a rod bearing and it wasnt even that bad of a blow just really warn down. So new pistons and im re surfacing the rods just to get rid of any imperfections, so over size rod bearings. So should I get the crank balanced or no Ill be putting new rods new pistons and a 2.2 stroker kit in in 4 months when I get back from a job. Thanks for every thing guys... and or females.
With spun rod bearings there is definitely a chance that the crank will need to be shaved to clean up abrasions on the journals, and in turn you would have to run oversize rod bearings. Balancing may not be totally necessary depending on how scarred up the journals may or may not be. When you say stroker, do you mean stroker rods and pistons or crank as well?
you need over sized rod bearings when you have the crank down.
when rods are resized, a small amout of material is removed from the rod and cap mating surfaces and the big end honed back to factory spec.
so if you have a crank that is std and has been just polished, and resized con rods, you will need std bearings.
are you doing a BSE? if you are not, and keeping the enging close to stock for now, the factory balance will be fine.
You can't increase stroke without changing the crankshaft, or at least having it offset ground.
This. :thumb:
It's a 420a, so no BSE.
This kit consists of the following components:
Brand New Forged 90mm Stroker Crankshaft
Eagle Connecting Rods
JE Piston Kit w/Ring Set
ACL Engine Bearing Kit ( Rods and Mains )
It says it comes with a new crankshaft???
QUOTE]
^^^ This :thumb:
there is only 2 ways to increase displacement, a bigger bore or a longer stroke
changing just the rods and pistons, can give you a long rod engine but not increase the displacement of it.
for "common" refreance the 350 chevy comes with a 4 inch bore and a 3.480 stroke and a 5.7 con rod
now if you do the simple 6 inch rod swap the pistions will have the wrist pins located closer to the ring pack, the 6 inch rod has chaged the rod to stroke ratio with no increase in displacement.
now, we take the same 350 chevy, and pull the crank/rods/pistons
we keep the 4 inch bore but replace the crank with a modified 400 chevy crank that has a 3.750 stroke, you now have the 383 CID engine
This. :thumb:
Yes I am aware of the need for another crank to build a stroker, I was just a little unsure where he was going with it. Since he is talking about balancing the original crank despite the fact that he is planning on doing a stroker soon.
