is it my starter? Transmission or balance shaft?
foxracing4500
336
9
Jan 21, 2012
Europe
I dont want this be be another weird sound thread but when I was on the highway going to a Dr. appointment I got off the exit and as I came close to the red light (40ft) and I hear this whinning sound, kinda like a belt snapped and a pulley was revving really fast. It did it again going to work but I made sure I checked all my warning gauges, rpms were right near 1000, vacuum was normal, oil pressure normal etc. I havent had a chance to tell where the noise is oringating from because as soon as I stop and pop the hood its gone. Also sounds like something between the engine and transmission is popping out and free revving, here is what I checked
Starter - sucks, sometimes it takes forever to start, is it possible for the starter to engage on its own while the engine is runing?
tranny fluid looks great but I did change it a 1 1/2 months ago.
belts look fine but I cant check my balance shafts and I did have oil leak where the timing belt is so could the oil have made its way in to there and the sound I hear is my balance shafts slipping?
now this is weird I was messing with my automatic control lever tightening it and loosing it and when I tried starting the car I got nothing from the starter.
im sorry guys I did alot of searching and next time I am out I will post a video.
Sounds like your starter solenoid screwed up and sent the starter for a ride on the flywheel. I would pull it off and have it tested/replaced. You need a working one anyways.
very possible, btw I do have a battery relocation and the power wire is screwed on to the 4g wire on the distribution block, I take it I could have fried it?
