98mitsubishigst
- 1,526
- 16
- Nov 17, 2008
Pittsburgh,
Pennsylvania
Are these all right? =/
The balance shaft stud is connected to the gear and the bolt on the other side..
Then i put the Little freeze plug in on the front case (1st pics)
and i had a bigger one, and that one only fit in the one hole... (second picture)
instead of a bearing, i used a plug..
is that okay? because i read up on it .. and the blockoff bearing is just suppose to cover the little hole.
was it okay if i have the whole hole covered...
