Is it a bad transmission or electrical issue?
95'gsxxx
Sep 16, 2013
Treasure valley, Idaho
Sup Guys,
I need some help with my 97 automatic gsx. I don't know if its the transmision or something else. The car will shift from first to second but wont shift beyond that and reverse works perfect.
So far I dropped the pan and didnt see any shavings, but it looks like the previous owner crushed the pan and welded it together from the inside. So if there were any shavings they're gone now.
I took the car to autozone to test for any codes and came up negative. I also replaced the filter and added new fluids to no success and I swapped the TCU from my 95 gsx and nothing still the same.:(
Is there anything else i should check for or just go ahead and replace the transmission? Any help is greatly appreciated.
