92_talonGsXt
- 117
- 1
- Jan 1, 2009
lake forest,
California
Is cleaning CAS with carb cleaner ok,just wanted to make sure I'm not harming anything
No, it's not ok. Carb cleaner has oil in it. The only thing to clean your optical cas with is keyboard cleaner. Did you take it apart?
Just don't get any of the brake cleaner near the electrical connections, where the wires go into the sensor. Spray some cleaner on a rag then wipe it down, don't spray it directly on the CAS.
If I can sandblast/powdercoat a CAS/cover, then brake clean will be fine. Especially when you use brake clean is used to prep the parts for coating.
A black top CAS might be different though as it has a plastic cover. Brake clean would still be fine, but other cleaning solvents that are harsh might cause damage.
