Is a 93-94 1G DOHC 2.0 NA flywheel a 7 bolt?
Bluesideup
119
May 28, 2009
Orange County, California
I am doing an engine swap and my trans won't work with the 1G 6 bolt turbo flywheel, it will however work with the NA flywheel.
My engine is a 95 so I need a 7 bolt flywheel. Looking on parts websites they list all 7 bolt engines under the same part number. I can't find a pic on here after exhaustive searching.
Obviously the issue is the flywheel diameter as the larger 6 bolt turbo flywheel won't fit in my bellhousing. Is the 7 bolt flywheel smaller?
The trans is an FM22 in a Mirage and I have to use a 95 motor to get my CARB sticker.
If you read the next line it says I have a 7 bolt motor so no it won't work, hence the point of my post.
Let me simplify....
I have a 7 bolt engine
I need a flywheel with the same diameter as a 6 bolt NA DOHC motor
Is the 93-94 NA 2.0 DOHC a 7 bolt engine and is it's flywheel different from the turbo engine's flywheel?
thank you for the help I really appreciate it! I'll post pics when I get the flywheel. Not sure if I'm going to buy used or new. Generally I would say new without a doubt but this is a GRM $2009 Challenge car.
