Irregular boosting issue
moi1463
89
Aug 9, 2008
Jax, Florida
I have a 95 gsx. the problem is that the car would sometime boosts fine, drives normally. but at times, it would not hold boost whatsoever. When the car is rev'd to about 3k, the boost would sputter and feels like the boost would not hold. this happens at irregular time. from a first start in the morning or happens after 30 mins of driving when i shut off the car, and restart it right after. i have changed the airflow sensor (new), Manifold pressure sensor (new) and ECU (used). Still nothing. no check engine light is on, but read from the scanner and the code is P1400. followed the trouble shooting diagram, and calls for bad ecu or manifold pressure sensor. So i have no clue where else to look.
no i haven't, i didn't think it was leaking because when it runs fine, i'm boosting at about 14.5 psi.
What turbo are you running? Cause it could be a wastegate problem. My friends 1G had the same type of problem and it was because the wastgate rod got jammed on the spring housing
it's the stock turbo. Is there a way to test the wastegate? I'm about to upgrade the turbo, but i want to fix this problem first. So if it's the turbo, then i can kill two birds w/ one stone.
Just check to make sure that it opens and closes without sticking. the stock t-25 is junk the wastegate is weak. mine would go from running 10 psi or less then spike around 18-20!
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
