Intermitent Idle When Warm
uva207
Dec 2, 2002
Hagerstown,
Alright, here is my problem. My car will idle fine upom start up and will continue to idle fine throughout the day. The only time I experience problems is when the temperture outside starts to warm up (around 50-60 degrees). It will idle anywhere from 1000-2500. I can sometimes lower the idle by pressing the gas pedal quickly and completly to the floor. This will usually lower the idle to around 1000. I can also lower the idle by physically pressing over on the throttle cable on the throttle body. Its almost like somehting is not letting the cable return to the home position.
Adjusting the BISS will adjust the idle but idle still surges at warm temperatures. How long I drive the car dosent seem to have as great of an effect as the warm weather does.
Vaccume pressure around -15 to-20 at idle. No leaks found.
Any help with this would be greatly appreciated.
95 eclipse gst :dsm:
I too havea problem with a rough idle when the engine warms up. IT is fine when I first start it and drive but once it is closer to operating temperature it gets rough and drops down to 500 rpm sits there then goes back up and then will idle for awhile but it eventually dies or if I hit the gas it will go up and then on the downsweep of the rpm it dies. Changed the coolant temp sensor and it seems to have gotten somewhat better but it is definitely not solved.
Well, I dont think I have a sensor issue because when it is ideling high, if I put the gas pedal to the floor quickly and then release it quick then the idle will drop somewhat....
I am thinking either too tight or loose a throttle cable or butterfly valve getting stuck partially...
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
