idle issues when warm
Mits3gts
188
Sep 30, 2004
bellingham, Massachusetts
this is probably a common DSM problem,and i have searched but didnt really find anything that sounds like this..
when starting the car when the motor is warm,it idles very low and almost wants to stall,i can drive normal and then its fine. car runs perfect anytime else. just when i go somewhere shut it off,do whatever,then start it back up when warm,it idles very low.what does this sound like? thanks
Well tonight in fact I found that my throttle body did not have a good ground so I ran a ground strap from the screw on top of the throttle body to the firewall. The throttle closed switch needs a good ground the ecu can read or it wont idle worth a crapola. Shes fine now. Sean
My car does the EXACT same thing...but not all the time. And sometimes, it will even shut off! It's kinda embarrassing and annoying. I heard it could be the ICS or something.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
