Intercoolers for a 1g
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
Im looking to find an intercooler for a 1g dsm, something that I wont have to cut anything, or relocate anything, and maintain the crashbeam.
Intercooler is going to need to be able to handle a 16g with at least 20lbs-25lbs
I was thinking about going with this
EXTREME PSI : Your #1 Source for In Stock Performance Parts
and welding flanges on it so I can bolt it under the crash beam.
Already looked at em. I havent seen one true bolt on fmic kit for a dsm. The punishment racing kit is the closest Ive seen
the type of intercooler you want depends on the type of horsepower your going to have, if you have a intercooler to withstand an amount it could drop ## psi but if your going to run near stock with simple bolt ons thats a different thing aswell.
Check out VR-Speed Factory. I think they are still on back order, but there are great reviews on it. I should get my kit from them 1rst week of April. You can always get a ETS core and make custom piping, all depends on you goals for the car.
If that's your case then consider doing a thick side mount. I'm pretty damn positive there is no front mounted core that will fit without removing or cutting anything.
If I were you, I would go with a huge-o thick sidemount and a meth kit to cool it a little more and allow you to run more timing. You won't have to fab up anything and you would have an awesome sleeper look too. :thumb:
