Intercooler
Had grass an everything smashed into it an I sprayed it out with the water hose an no water seemed to get inside how do I perform a pressure test?[DOUBLEPOST=1408922000][/DOUBLEPOST]It's also the backside of the intercooler
cap off one end, BLT with a gauge on the other side. Then add air to desired psi. Spray with soap and water. It should hold the pressure.
Plug up the inlet and outlet of the IC. On one plug have a port to apply air pressure much like airing up a tire. Use a pressure gauge or a nipple from a tire and a tire gauge. Put in more pressure than what your boost pressure will be and see if it holds. Spray the outside with soapy water just like you would for checking a tire for a leak.
Ok cool I'm going to give it a try an see what happens it was smashed into my centermember from Horton an unseen speedbump also have another question about the air bags they also popped and I replaced them but haven't plugged them in yet now once I change the airbag control unit can I Jus plug them in? An since they popped will that reset my tune? Using Dsm link
As for your tune, I'm not positive on how the dsms handle all that but the tune is written to the ecu, obviously a different control module than the computer. I don't for see it affecting your tune in any way. You'll likely have to take the car to a body shop to have the light reset so the srs system is functional again.
  • For sale 2g Clean title
    • FirstTimeDSM
  • For sale 1g 1g BR upper intercooler pipe. Stainless Steel
    1g upper pipe. Early BR. 2.25 inch Stainless. Bead Rolled ends. BOV flange is gone...
  • For sale Anyone interested in brembo front brakes from a evo x?
    Hey guys I happened to come across evo x brembos that work great for a good price !
    • SheNeverRuns
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
