intakes?
after market manifold are not that important for our car unless your making like 400hp other wise like i said its not worth it. the 1g mani will give better performance in high rpms and then the 2g mani is like a perfect street mani not too big not too small
well got the t3 twin scroll hx35, stock 6bolt w/ 2g head with kelford 272's. and im in the middle of my awd swap and it would be the perfect time to upgrades sooo i went from there
Unless you ganna make over 600whp imo I would just stick with the stock one or swap over to the 1g manifold. If you wanna spend the money to get one your more then welcome but I don't think it is neccassary with the goal or setup that you have now.
There is absolutly no reason to use a 1g manifold. NONE.
The RVR or Evo 3 manifold is superior on a 2g head. It keeps the low end, while allowing for more top end.
I know I was just saying it was a option if he felt like he wanted to change the manifold. But my main point was really not to change it you don't need the street one is good, but the stock is just as good. Unless you like 650-800 range I would get one maybe...
The 1g intake manifold would just make turbulence at the intake ports unless your ported the crap out of the head.
So would Cyclone.
RVR or E3. If your gonna port the head, you might as well get a Magnus v3.
yeah profile said i do, that was when i was set on purchase of it then i just started to think a little more and see the other options. Probably just going to get the magnus now because i know ill be building the car soon. :)
