Intake vs Headers
rc330
Aug 4, 2012
Dover, Pennsylvania
I have about $250-$300 to spend on an upgrade for my 2G Eclipse GS. I was thinking of getting either an AEM cold air intake or some headers. My question is, if I wanna get the most horsepower increase out of my $250-$300, should I get the AEM cold air intake, headers, or both but buy some random ebay tubes and switch it out with an AEM filter (which some people say gives you the same results). Would headers even benefit me at all seeing that my cat and catback is fully stock? Would I get better horsepower results out of a $250-$300 cat and catback?
I'm new to upgrades so sorry if this is a really dumb question LOL. Thanks!
Buy a coupler, some shiny pipe of your choice, and a K&N filter.
There you go, a budget cold air intake without spending all your budget on a premade kit with a fancy name on it.
The header will do nothing but drain your wallet and you will not feel an increase in anything.
Spend the money on nice tires in my opinion.
Or a nice set of speakers/and sub if you drive a lot.
It takes far too much money to speed up a n/a gs eclipse.
Buy a cheap ebay intake.. its just a pipe. I wouldn't waste the money going AEM. Then spend the rest on a quality header. cheap ones can crack and are welded like crap. You'll get a little more top end power.
Ya, that's kinda what I was thinking, just getting an intake.
2GCruiser: That's what I was wondering though, how much would it help me if I got some headers seeing that my cat and muffler are stock?
look..when i had my talon all stock i felt a bit more power when i installed my intake than headers..i also had the whole exhaust system stock..also the sound the intake makes is priceless
You would get better results out of a pulley upgrade. They are $250~ish with shipping
Then do a cheap intake + exhaust for $150 - $200 later and you'll really feel a nice free up of power.
If you decide to get headers you might want to make the exhaust "full" and just re-move the cat. Get your emissions done before ;)
When I removed my cat I felt a nice difference, you're going to be beating on this car I assume LOL so you'll want all the power you can free up :)
Good luck!
Yeah get some nice subs too if you drive a lot. It definitely takes a lot to get speed on the gs/rs. A nitrous kit is about $350 & would wake your car the heck up :hellyeah: but I wouldn't recommend that if you have a stock intake, stock cat, exhaust LOL.
what extra power?
That's what I was thinking. I put an Injen ram air intake on my 98 RS and I didn't notice a difference. Looked nice though, too bad it just made the rest of my engine bay look worse.
You should just get a cheap ebay catback it will help reduce some restrictions in the exhaust I seen them recently on ebay for $130 and an intake would be best since the stock ones are horrible..You can end up spending less then $200 for a catback and intake. You wont get too much of a power increase with a header
I would honestly not do bolt ons. Spend your money else where because you're going to end up spending hundreds of dollars for less than 10 hp. Dollar for dollar your best bet is probably a bottle. Other wise just enjoy good gas mileage and a good looking reliable DD.
i know not many people are fond of obx but! i run an obx header and cold air intake, the header is $200 and the intake was $90. i have a built motor and have no issues with my header cracking or anything like that. the cold air intake looks nice and sounds great the design is just like an aem but its two peice which makes it easier to take off and put on. my header is a 4-2-1 and personally i just like that style. you can get the megan 4-1 header which gives you better flow and just a little bit more torque and horse power. just for the future, if you bore out your throttle body and get a cold air intake with an under drive pulley from unorthadox racing you will be pretty happy. then you can put on full exhaust with your header. its not a ton of gain but it makes the car alot funner.
Hey when you are starting out with only 140hp 10 more is a big thing.
BK85
When I had a 97 GS the first mod I did was a AEM cold air intake and I noticed a difference. It's only like 5-7hp but it is noticeable even for someone not sure what mods to do.
Wrong, you in no way gained 5-7 horsepower with a aem intake. You can do the works and add exhaust, header, intake, pullies and you will likely gain 10 horsepower at the very most.
if you bore out your throttle body .
The stock throttle body is no where close to being a restriction on the stock engine.
Did you dyno that before and after LOL?
What he said is dead on ^^
What exactly do you mean by a pulley upgrade? Sorry, like I said, I'm new to this LOL
This is a pulley:
Code:
http://www.andysautosport.com/mitsubishi/1995_1999_eclipse/performance/engine/pulley_kits/unorthodox_racing/
You'll need to get one for the 420a those are for the GST & GSX. I tried to Google but I didn't see it, I bought mine about two years ago and it was an unorthodox pulley. Still running good to this day.
Light weight under drive pullies. They are lighter so they have less rotating mass, and they are also smaller so they turn the accessory slower and use less power from the engine. They don't make the engine produce more power, they just free up a little bit of power.
I've been down this road... Spend the money on nitrous or a turbo setup. Anything else is a waste of money. You can do every bolt-on mod known to man, spend thousands in the process, and ask yourself why your car is still so slow, or go turbo/nitrous.
yeah? and i didnt say it was a restriction did i? its just something cheap you can do for better throttle response after you do some other things. the guy only has a few bucks to throw at his car. i was just giving him some options down the road to make the car funner like i said.
Well if it isn't a restriction than making it bigger will do absolutely nothing for him except hurt velocity which will usually make less power.
If I were you I'd spend all your money on suspension upgrade. Anything you can do to stiffen it up. The most fun you can really have in a 420A DSM is going out some backroads and taking tight turns at high speed. Not pulling hard or going fast in a straight line. Seriously get some suspension upgrades, good tires, and have fun driving the car. Don't waste your money trying to make big power on it.
not if he does it right with other upgrades. like i said in the future down the road...
im not saying go bore it out first thing and throw it on the car. just giving him some other options. your right about velocity but if he does some other things first it does help.
