Intake manifolds and slim fans
skandel11
49
Feb 26, 2008
Quakertown, Pennsylvania
first thing. im about to pull the head off my car and im thinkin about putting a diff. intake manifold on like a jm fab or magnus? idk yet my question is dose someone make a aftermarket manifold that has all the vacumm ports on it and everything just as the factory one?
also..
im looking into slim fans and i was wondering if anyone makes a after market slim fan that bolts rite up and connects into the factory harness for the old fans.
if someone can help me out it would be great!
:dsm:
To answer your question abou the fans, checker, auto zone, and many many other auto parts stores carry slim fans that work well. You can wire them into the stock wiring harness very easily. I believe they have 10" fans, and 12" fans. I think I paid about $50 or so for the 10" ones. I have two 10" fans on my setup.
You can also buy an automatic fan swith that works way better than the stock setup. I think I paid $25 for mine and you stick the sensor into the radiator fins and mount the "switch" in a accessible location. You can adjust the fan switch so that the fans come on almost exactly when you want them to (temperature wise). I had to mess with the dial on mine quite a bit, but once I got it right the fans never missed a beat. The car runs a little bit cooler than it did before with the them staying on a bit longer than they did with the stock fan switch. Just my 2 cents. :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
