Intake Manifold Gasket Leak
mostapasta
72
Mar 13, 2004
N/A, Michigan
I put a new intake manifold gasket on and it leaks like crazy when I do a boost leak test. I'm sure all the bolts were tight. I'm using a metal gasket similar to the one from diamondstarmotorsport.com and I was wondering if I should put sealant on it or copper spray it to make it seal better? Any advice is welcome!
Make sure both surfaces are clean you should not need a sealant. But if you are having trouble I would use a copper see if that works. Becareful with the bolts into the head they will strip out just keep it in mind while tightening.
make sure you tightened them starting at the middle and working your way out, if you do the incorrect pattern than it wont seal correctly
also you dont need silicon sealant or copper spray if it is a crush type gasket, as in there is a raised area that gets crushed down when you torque it.... otherwise you do
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
