Intake Manifold Design
AbsurdParadox
Jun 1, 2004
Wichita, Kansas
Wasn't sure which Advanced Tech forum to put this in... so here you go :)
I'm doing a 4g63 into a Starion swap, and of course this means I need a manifold that points the other way. Now, with the cost of the available ones out there being rather high, and the fact that very few for this application actually exist, I thought I'd try my hand at designing my own (I'm also a bit sketchy on the flow properties of a modifed stocker).
Now, the specs I am using are based on quite a bit of research as to whats best, and whats too extreme. The runner diameter is based on valve size, it will be pretty extreme for a stock valved head at near stock power, but with +1mm valves and considerably more CFM, considerable gains will be seen. The runner length, as far as I have seen is near as short as one should go (supposedly further gains will not be seen unless you're doing something just insane).
Now my MAIN concern is adverse effects to having the runners shaped the way I am hoping (and hoping that there aren't much in terms of effects). The reason for this is completely due to clearance issues. I know the image is a bit crude, but if you can imagine, the runners curve down towards the head just like any stocker, but also backwards a bit (to move the plenum forward). I wouldn't think this would be much different than the curves in a stock-type manifold's runners. Now, depending on clearnance I MIGHT be able to have the plenum sit STRAIGHT off the head, but I think the power steering box/lines may be in the way. Not 100% yet. Oh, keep in mind the bends will of course be smooth mandrel-style bends, and the runners will be belmouth at the plenum... I'd love to have them venturi at the head, but not sure how feasible that really is, but it can supposedly make quite a difference in performance.
Anyway, the image:
Let me know what you guys think. Any comments or concerns are greatly appreciated!
seems very involved. i had jim at JMFabrications make me one for $450 to my complete custom specs. he did a greta job and im absolutely happy. that being said, go for it. if it works then your a hero. if it doesnt then no harm no foul it wasnt supposed to work:p
Are you experienced in manifold design? Any comments on mine? Also, willing to share your specs and observed gains, if dynoed? (understandable if not LOL But yeah, I'll give him some consideration. I really wish I had the metalworking skills to just build it myself.
DSM90AWD said:
FYI.. check out this PAGE where a stock 1G manifold was modified for use on a Starion.
Thanks for the link, some good pics there, but yeah, as I mentioned in my original post, I'm a bit wary of doing that, as the manifold was only designed with airflow coming in from one side, and I fear each cylinder not getting equal air/fuel ratios. I mean, its probably fine, but *shrug* I enjoy reinventing the wheel once in a while I suppose!
Just an idea I thought I'd throw out; Since you're talking about pointing the other way, would an intake manifold off an Evo 8 work?
Haha I thought of this long ago (not to put down your idea), and every forum I posted my design also got this reply! I've been TOLD that the bolt patterns are not the same, but I haven't actually confirmed this myself. A friend of mine has an Evo, I should just go look sometime. Thanks a bunch though! I'll post back with the info, once I find out.
or i could send you a photo of my intake manifold gasket i have (i have a spare thats used but didnt fall apart, long story) and go to a mitsu dealer and ask to see an evo 8 or 9 intake manifold gasket, they will probably have it since those cars are still made, and compare the bolt patterns...
